I was wondering when tig welding mild steel do you need to remove the copper colored coating from the filler wire prior to using it?Thanks TomLincoln PT225Lincoln Tombstone ac/dc 225Hobart HH180Miller ThunderboltPlasma Victor O/A
Reply:nope, just use the filler as-is.
Reply:I will add that if it's dusty or dirty from laying flat or exposed, you may want to wipe it down quickly with acetone...just like prepping your work surface (weldment).John - fabricator extraordinaire, car nut!- bleeding Miller blue! http://www.weldfabzone.com
Reply:Thank you very much. That is the way that i have been using it but i wanted to make sure.Lincoln PT225Lincoln Tombstone ac/dc 225Hobart HH180Miller ThunderboltPlasma Victor O/A |
