teardrop trailer welding rod ?
发表于 2021-9-1 00:57:24 | 显示全部楼层 |阅读模式
Ive decided to go with 3in channel 3/16 and some 2by 3 rectangular steel also 3/16.Ill be using my ac 225. I have and like 6013 but had just about decided to go homedepot and get some  7018 which i never have liked,but was going to practice with it until i did  But just now reading that post e7018 has turned me off it,is my 6013 alright for my little trailer? Thanks fellas
Reply:for general purpose fabrication the 6013 will do you a great job.  That is what it was designed for.  I have put together tons of trailers that were built with nothing but a 6013 and and never had any trouble with any of them.  on the AC 225 you will be hard pressed to get satisfactory performance out of a low hydrogen rod.  ~JacksonI'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:E 6013 and E 7014 would be just fine for your application.
Reply:For what you are doing and most mild steel work the 6013 is just right. As a personal note I don't have a huge selection of rods available locally but the 7014 we have available really gets to my nasal passages, I hate the smell and it causes me discomfort and I don't have to be the user, it can be someone else, if I get a whiff that's enough.Clive
Reply:7018 won't work with that welder, 7018AC will run fine. Like everyone else has said if you're making good welds with 6013 there no reason to change.
GMT+8, 2025-12-20 07:32 , Processed in 0.069447 second(s), 18 queries .
