Welding a Welding Stand
发表于 2021-9-1 00:57:23 | 显示全部楼层 |阅读模式
I have just finished welding a stand to hold all of my welding gear.  It holds a welder, tig and mig modules, water cooler, plasma and small vacuum system.  Now that I have everything installed I want to weld on some hose and cord holders and a few other items.  Can I do this with all the gear and tanks mounted without damaging anything or compromising safety.  I've not done this before and want to make sure I am not going to compromise anything.Thanks
Reply:Just to be on the safe side I would suggest removing everything before welding. It's hard to set something on fire if it ain't there.Clive
GMT+8, 2025-12-20 07:32 , Processed in 0.112738 second(s), 19 queries .
