Smith Little Torch & Sheetmetal
发表于 2021-9-1 00:57:20 | 显示全部楼层 |阅读模式
GreetingsHas anyone used a Smith Little Torch (O/A) to butt weld sheetmetal?How thick metal - which tip etc...  How'd it work for you?ThanksPete
Reply:I've  used a smith little torch for sheet metal.  Primarily18 gauge.  Off hand I don't rememberwhich tip(s) I used.  But since I don't do it every day I typicallyhave to spend about 10 minutes playingbefore I get properly set up.   I use scrapsof mig wire as a  fillerLots of fun.Not sure it is the *best*  or fastest way of joiningsheet metal. You are heating the metal till it meltsso you can't do things like  use Al/Cu backing to keep distortion down.-Almus
GMT+8, 2025-12-20 07:32 , Processed in 0.314464 second(s), 18 queries .
