查看: 14|回复: 0
Help filling butane soldering iron
发表于 2021-9-1 00:57:00 | 显示全部楼层 |阅读模式
hey all.. i just received Philips ECG J-500KT Soldering iron on ebay and the first thing i did was go down to the local hardware store and pick up some butane (BernzOmatic). I got home and attempted to fill up the torch, however when i pulled out the butane tank after i filled it a little bit the torch would begin to leak and after about 10 secs empty itself. am i doing something wrong or is this just a broken valve on the torch?? any help would be greatly appreciated. Tanks!
Reply:Either the valve didn't seat straight or it's bad. Try giving a few more shots of butane and see if it seats. It used to be that the butane would come with different nozzles to get a better fit on differnt brands of lights or irons. Now days you're kinda stuck with one tip that doesn't fit anything perfectly.
Reply:OK, that's it, here's my first reply to a soldering thread! HaHa! Electric soldering irons are the way to go,Here You Go,everything else is...I will never go back to guns or any thing else for wire soldering.NASA spec trained solderer (military).City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:I hope I did not turn you off to soldering! I did a recent repair to an older shop charger. It seems they always melt wires at the transformer from us starting motor homes with dead batteries!The tool of choice:-Weller 120 watt iron. The victim:-200 amp shop charger with new pigtail soldered onto transformer.The repaired connection:- 120 watts burns solder real good!Just a butt connector to close the circuit, and done!City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Not too far gone from being a third world welder!City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
GMT+8, 2025-12-21 10:23 , Processed in 0.124484 second(s), 18 queries .
