查看: 13|回复: 0
Need some information on Codes ASAP
发表于 2021-9-1 00:56:33 | 显示全部楼层 |阅读模式
Hey fellows do you know where I could get some ANSI, AWWA; and ATSM databases. I am thinking of putting in a bid on a job and need these codes. Is there a place where these are on public databases? Everywhere I look someone is trying to sell me a book. I just need a few to see if i am going to be able to so this job or if it is over my head. Thanks in advance Guys and Gals.
Reply:A large library or preferably a college engineering library would be the only place I can think of that you can look at them for free.  Not even positive since we only had hard copies when I was in school (many years ago before personal computers).  ATSM will sell the individual codes to be downloaded at a fair price and probably ANSI would also.  Check out their web site; they even had abstracts of the major codes to read before purchasing when I needed some additional codes.  I do not know about AWWA.Finally, if you are bidding on a job, ask the engineering co. that compiled the bid docs if you could go to their office and view them there.  I have had a couple of guys do that in the past.Good Luck on the bid.
Reply:http://www.standard-building-code.com/astm-codes.shtmlhttp://www.constructionbook.com/ansi/Second link shows alot of other links hope this helps.AWS CWI Hypertherm 850 plasmaLincoln LN-25Lincoln SAE 400Miller Big 40D28' X 36' X 14' Shop_____________________________________Tools are not the the skill but simply tools!
Reply:thanks fellows. Ill try that out.
Reply:Thank you Mr. Dipper DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:See alsohttp://www.ansi.org/or go right to their 'store' at http://webstore.ansi.org/How about the AWS as well?http://www.aws.org/And the AWS bookstore athttp://www.awspubs.com/
GMT+8, 2025-12-20 08:19 , Processed in 0.101880 second(s), 18 queries .
