crazy
发表于 2021-9-1 00:56:30 | 显示全部楼层 |阅读模式
We have a frame at work that the welding engineer set paramiters for:    it must be welded with 90/10 gas at constant voltage with a wire speed of 400 in. and voltage of 27 on a lincoln 3 phase welder with .045 wire. (material is .312-.375in.) Talk about hot!!
Reply:Which "green" lines does your shop build ?Anything worth doing is worth doing RIGHT
Reply:Originally Posted by jdwelderWe have a frame at work that the welding engineer set paramiters for:    it must be welded with 90/10 gas at constant voltage with a wire speed of 400 in. and voltage of 27 on a lincoln 3 phase welder with .045 wire. (material is .312-.375in.) Talk about hot!!
Reply:It sounds like you will be welding with a metal core wire....
Reply:We build cotton pickers, high cycle sprayers, grain drills, and tillage equipment. I am a tillage welder.
Reply:A few more volts and it would be spray. DavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-20 08:23 , Processed in 0.069888 second(s), 18 queries .
