Acteone resistant spray bottle?
发表于 2021-9-1 00:56:22 | 显示全部楼层 |阅读模式
I bought one at home depot for $6 an it says chemical resistant in big letters across it and it stopped working after a day  Is there any one that knows if there is one that works for real?
Reply:Originally Posted by WANNAWELDI bought one at home depot for $6 an it says chemical resistant in big letters across it and it stopped working after a day  Is there any one that knows if there is one that works for real?
Reply:Hers the one I bought. It sounded like it would do the jobJANITORIAL & INDUSTRIAL PRODUCTS- #SM-87Spraymaster - The Ultimate Sprayer. This heavy duty chemically resistant sprayer will stand up to all types of chemicals..even most solvent based liquids that destroy other sprayers. Dispenses 3 times the volume per stroke as standard sprayers. The unique silver and blue color scheme quickly indicates that this is no ordinary sprayer. Spraymaster is the only sprayer backed with a 5 year guarantee!!!32 oz.So much for 5 yrs Attached ImagesLast edited by WANNAWELD; 08-18-2007 at 07:01 PM.
Reply:Try an experiment with a shampoo bottle with a flip top.  We used to use em to carry alchohol and Tri 111.  The bottles are typically chemical resistant as well, and the flip tops are conveniant if not a spray.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:I use these for Acetone, MEK, and Lacquer thinner.....http://www.usplastic.com/catalog/pro...uct%5Fid=14641Patrick
GMT+8, 2025-12-20 08:21 , Processed in 0.298192 second(s), 18 queries .
