Dba
发表于 2021-9-1 00:56:22 | 显示全部楼层 |阅读模式
I have done a bit of certified welding on structures, but I have never heard of a DBA.  Could someone enlighten me?  I think it has something to do with anchored rebar.-MikeCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Dba...I come up Duh..And no I'm not buying a Hundai!!!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:We figured it out Dowel Bar Anchor.Last edited by TozziWelding; 08-16-2007 at 08:35 PM.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Don'tBelieveAnything?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Dibenzylideneacetone: used in sunscreen?dBA: decibels?  Maybe loud or quite welding?R
Reply:Doing Business As......
Reply:I'm with TEK, I've always known a DBA as "Doing Business as"  but I guess there could be other uses....I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:What they ^^ said.Anything worth doing is worth doing RIGHT
Reply:So now he has to take a "Doing Buisness As" cert test..Funny..very funny.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Anchored reebar, YEAH, THAT'S THE TICKET!, Yeah! Lunchtime reebar rock anchors!City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by BrainfarthI have done a bit of certified welding on structures, but I have never heard of a DBA.  Could someone enlighten me?  I think it has something to do with anchored rebar.-Mike
Reply:Would you know if using A706 or A615 rebar would be an exceptable replacement for these studs?Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by BrainfarthWould you know if using A706 or A615 rebar would be an exceptable replacement for these studs?
Reply:The engineer approved the A615 as a suitable replacement for A706 but nothing was mentioned about preheating.  Since A615 is 60ksi, wouldn't that make the A706 more proned to embrittlement?  And even at that, 70ksi no worse than the 7018 rod that I am going to use.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by BrainfarthThe engineer approved the A615 as a suitable replacement for A706 but nothing was mentioned about preheating.  Since A615 is 60ksi, wouldn't that make the A706 more proned to embrittlement?  And even at that, 70ksi no worse than the 7018 rod that I am going to use.
GMT+8, 2025-12-20 08:19 , Processed in 0.093016 second(s), 18 queries .
