The Best Way to Polish SS?
发表于 2021-9-1 00:56:13 | 显示全部楼层 |阅读模式
I have the truck rack finished but the polishing is not going exactly as I expected.I started with the Flap disc 60 then 80 grit and left the welds just a little high then flattened them with a belt sander.  I like the results from taking the belt sander and riding on the front roller but I cant do everything this way singe it is directional.  So I grabbed the DA sander and slapped a 100 grit on... not exactly what I was going for.Suggestions?Me!
Reply:High-Speed body grinder...you need wheel speed, a light touch and a fine grit.Anything worth doing is worth doing RIGHT
Reply:Like this:http://cgi.ebay.com/5-HIGH-SPEED-AIR...QQcmdZViewItemMe!
Reply:I did a SS butterfly http://www.weldingweb.com/vbb/showthread...t=wedding+giftand I used a pneumatic die-grinder with twist on scotch-brite pads of varying degrees of roughness to achieve a polished look
Reply:Originally Posted by Me!Like this:http://cgi.ebay.com/5-HIGH-SPEED-AIR...QQcmdZViewItem
Reply:Thats a good idea but I was hoping for something a bit faster.  It's a bout 20' of 2x2 sq tubing = 1,920 sq/in of surface + th supports.Me!
Reply:olddad do you have a good spot to get the discs and what grit?Me!
Reply:LOL...I hear ya...know what my first thought was when I read the title ?"The Best Way to Polish SS?"...have someone else do it !!...LOLAnything worth doing is worth doing RIGHT
Reply:I "usually" just buy off ebay, most of my discs haven't been over 35 cents each that way. There is no cheap retail on the good stuff that I know of, if you find one let us know.Anything worth doing is worth doing RIGHT
Reply:I will ship it to you...Me!
Reply:Wrong answer buddy...LOLAnything worth doing is worth doing RIGHT
Reply:LOL... !Oh your not offering, How fine of a grit would you recommend?Me!
Reply:Just did some looking on Google, oh man this is going to take a loooooooooooonnnnngggg time to get a nice finish.  Oh well at least I don't need to paint it when finished LOLMe!
GMT+8, 2025-12-20 08:19 , Processed in 0.112108 second(s), 18 queries .
