Where can I find a .025 mig wire for my lincoln?
发表于 2021-9-1 00:56:13 | 显示全部楼层 |阅读模式
Where? I got stuck buying .030 solid wire for my Lincoln Pak 100 Mig. I'm talking about the 8" spools. Now I have two .030 spools that I don't like welding with. I like the .025 wire because I can actually "melt" the wire and make decent welds.Anyone want my .030 spools?Last edited by mpower; 08-24-2007 at 07:42 PM.
Reply:.023 is better.  Try napa for 10 lb spools.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I'll take em'.  How much shipped to 98273?
Reply:Originally Posted by WelderBoyI'll take em'.  How much shipped to 98273?
Reply:70S-6 ? What's your 10/20Anything worth doing is worth doing RIGHT
Reply:42bucks shipped to your door. I'm not making any profits off of them. Can the .023 be used for my lincoln? I thought it can only use .025 as a minimum?
Reply:mpower, you may need to get different drive rolls.  Maybe a smaller liner since the small wire can bundle up in a large liner.  It'll probably work if you tighten down the drive rolls for .025, just keep the whip straight and the gun at a straight angle.  You will need .023 contact tips though.
Reply:Originally Posted by mpower42bucks shipped to your door. I'm not making any profits off of them. Can the .023 be used for my lincoln? I thought it can only use .025 as a minimum?
Reply:Sweet=) Thanks for the info!
Reply:Originally Posted by olddadWhat's your 10/20
Reply:Home crepo has a good price on wire.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by TozziWeldingHome crepo has a good price on wire.
Reply:Yup, thats where I get stuff for my baby MIG.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by mpowerWhat does this mean?
Reply:Originally Posted by WelderBoy Originally Posted by TozziWeldingHome crepo has a good price on wire.
Reply:I didn't realize there was an .025 wire, all I've ever seen close to that was .023.
Reply:Originally Posted by Alan NI didn't realize there was an .025 wire, all I've ever seen close to that was .023.
Reply:You can ship 2 10# spools anywhere in the 50 US states for under 9 bucks via USPS the post office in their bulk rate box so that should help somebody.As for cheap good wire see Jeff Noland at http://www.usaweld.com his S-6 wire runs great...BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:Originally Posted by aametalmasterAs for cheap good wire see Jeff Noland at http://www.usaweld.com his S-6 wire runs great...Bob
Reply:.025 is a lincoln thing. usaweld.com doesn't carry it either. damn. got to get .023 then. I don't think they'll fit both my 8" spools in there for shipping would they? If they do, someone can have it for cheaper!
Reply:.025 wire at netwelder http://search.stores.ebay.com/netwel...20wireQQsofpZ0Anything worth doing is worth doing RIGHT
Reply:.023, .024, .025....all the same stuff.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by olddad.025 wire at netwelder http://search.stores.ebay.com/netwel...20wireQQsofpZ0
Reply:Originally Posted by 69 chevyYeah, I'd buy that stuff just as quick as I'd buy diesel oil with "VIRGIN" 15-40 on a plain white label.
Reply:Originally Posted by Alan NI didn't realize there was an .025 wire, all I've ever seen close to that was .023.Originally Posted by David R.023, .024, .025....all the same stuff.David
Reply:Originally Posted by olddadYou'll note there's no recommendation from me, I simply put up a link to the .025 wire he wants for whatever reason. I myself can't see what difference two thousandths makes ??
GMT+8, 2025-12-20 08:21 , Processed in 0.197602 second(s), 18 queries .
