Weld inside & outside seams/joints?
发表于 2021-9-1 00:56:09 | 显示全部楼层 |阅读模式
Say for example when your welding angle for a cart, table, etc. Where they join together do you weld the inside join/connection and the oppositte, outside connetion?
Reply:Originally Posted by BadAzzBuSay for example when your welding angle for a cart, table, etc. Where they join together do you weld the inside join/connection and the oppositte, outside connetion?
GMT+8, 2025-12-20 08:17 , Processed in 0.067222 second(s), 18 queries .
