Hey Olddad
发表于 2021-9-1 00:56:07 | 显示全部楼层 |阅读模式
Have you heard any more info on the Rocky Mountain Express?Arguing with a Welding Engineer is like wrestling with a pig... after a while you realize the pig likes it
Reply:Naw..I quit looking when I found out the probability of wire welding. That particular job is only good for maybe another 1 1/2 years. Been burning wire long enough to be sick of it, I've only got a few years left and I'll spend them burning rod. I would have had to switch to the ethanol plants when that was done so I'll just aim that direction. If I could get into "shut-downs" I'd go that way, better suited for me, I'd be able to keep what I already have for business. Can't be gone for months at a time and not expect my regulars to find someone else.Sorry I couldn't help.Anything worth doing is worth doing RIGHT
Reply:No problem, I was just curious where the project is at.Arguing with a Welding Engineer is like wrestling with a pig... after a while you realize the pig likes it
Reply:It's close to SE Missouri right now. They were running to a line there and then wintering over before starting the last leg was my understanding.If anyone's interested, Local 798 outta Tulsa is the contact.Anything worth doing is worth doing RIGHT
GMT+8, 2025-12-20 08:16 , Processed in 0.093423 second(s), 18 queries .
