Help identifying welder
发表于 2021-9-1 00:55:59 | 显示全部楼层 |阅读模式
I am trying to find which model a welder is that i am going to buy. It is a Lincoln Invertec V300 Pro... i was told to find the product number, but all i can find is the Code number, and serial number  how do i tell if it the advanced process welder?
Reply:Please refer to your other post. You can ask multiple questions within one post. However, multiple post regarding the same machine will just confuse you further. That is a 3 phase machine, unless you have 3 phase electric power, you won't be able to use it. As a reference to other members, to help answer his question, here is his other post: http://www.weldingweb.com/vbb/showthread.php?t=14420Last edited by MicroZone; 09-07-2007 at 01:39 PM.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
GMT+8, 2025-12-20 08:18 , Processed in 0.066767 second(s), 18 queries .
