generator to run a mig?!?
发表于 2021-9-1 00:55:59 | 显示全部楼层 |阅读模式
Hey all im hoping on some advice!! I have just managed to get a garage to start my project build of a Mini race car... but my garage has no power and untill i can move to a garage with power i still want to get on with my welding so the question is:Whats the best generator i can get hold of (ie fleabay) to run a mig 80 gas welder? i have tried going through the manual to see if i can find any input power values but with no luck, so fingers crossed for a reply
Reply:Look through the last few months of posts here for posts about welding and generators.Or search here for posts on welding/welder and generator.Basic answer is you need a generator with enough power at the right voltage and outlet to power the generator.  No, that's not a trick answer.  You need the generator to be able to send enough current at the correct voltage to the correct outlet to plug the machine into.
Reply:i do get what your saying heres a link to the mig....http://64.233.169.104/search?q=cache...ient=firefox-aINPUT VOLTAGE 50HZ: 230V-13AWELDING CURRENT AMPS: MIN 40 MAX 80OUTPUT AT 20% DUTY CYCLE(AMPS): 60OPEN CIRCLE VOLTAGE: 24so would this be suitable....http://cgi.ebay.co.uk/HONDA-EG-1900X...QQcmdZViewItem
Reply:Originally Posted by justafeindWELDING CURRENT AMPS: MIN 40 MAX 80OUTPUT AT 20% DUTY CYCLE(AMPS): 60
Reply:I get 6,000 watt generator.  13a @ 230 volts *2 = 2990 Watts.  Lincoln electric sez double the input current because of spikes and starting the arc.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:1 x output: LPA 110-130V 16A-4H/110V 2P1 x output: LPA 220-240V 16A-6H/220V 2PI'm no electrician, but isn't it unusual for a generator of this type to produce 16A at both 110-130V and 220-240V?What am I missing here?WeldingWeb forum--now more sophomoric banter than anything else!
GMT+8, 2025-12-20 08:17 , Processed in 0.092649 second(s), 18 queries .
