Dumb regulator question of the day
发表于 2021-9-1 00:55:55 | 显示全部楼层 |阅读模式
I currently have large O/A tanks,that I rent and don't use much.I just picked up some smaller tanks(B) acetylene size.Can I adapt my larger regulators to fit the smaller tanks or should I just get smaller regulators.I'm just tired of dragging around big tanks and paying rental.Thanks.
Reply:Hi 59ih340,  Yes you can get adapters. My setup is large reg's and a B acet. tank, with a Q oxy. I think the fittings are CGA-540 to CGA-520 or 510?, I'm sorry I can't be sure as I'm not home now, in NC on a buisness trip. However, any local welding supply should be able to set you up for $10 to $20 dollars.o.c.d.
Reply:I believe that they do make that adaptor. Just check you local welding supply shop.
GMT+8, 2025-12-20 08:16 , Processed in 0.093271 second(s), 18 queries .
