Scott
发表于 2021-9-1 00:55:54 | 显示全部楼层 |阅读模式
...just bought a deca 115volt 15 amp... inverter 100amp stick welder,great little welder but having problem with breakers in may apartment had a deca 135e wirefeed same problem.maybe just weld somewhere else!
Reply:Not a bad idea.  Landlord would probably to tell you to do the same.
GMT+8, 2025-12-20 08:21 , Processed in 0.414917 second(s), 18 queries .
