Looking for ESAB-Easy Grind Wire Source
发表于 2021-9-1 00:55:52 | 显示全部楼层 |阅读模式
GentlemenI am looking for two (2) two pound spools of ESAB Easy Grind wire.The two pound spools are no longer offered and are obsoleted.I need a spool of .023 and also a spool of .030.Would you experts talk to your suppliers and see if any of the warehouses have this on there shelf?I can special order the 11 pound spools but am not sure which gage is correct for my application and it is EXPENSIVE.I have a call into the ESAB factory rep and am awaiting his response. I am also waiting for the money tree to blossom in my back yard. Thanks for any and all help.Oldmics
Reply:Try some J.W. Harris "Twenty Gauge" it's available on a 2# spool, but it is not cheap, you could get a 11# "Easy-Grind" for 4 pounds of "20 ga."
GMT+8, 2025-12-20 08:17 , Processed in 0.067369 second(s), 18 queries .
