Oxy/Propane ?
发表于 2021-9-1 00:55:43 | 显示全部楼层 |阅读模式
I am in the process of setting up a oxy/propane torch for my home shop..I bought a nice used Smith Torch set up today for $100  Only about a year old and looks almost new..CW5A handle..Ive never owned a Smith but have heard plenty good about them. Anyway what pressure do you like for a oxy/Propane set up? Pretty similar to Oxy/ace???
Reply:About the same.  To cut a propane tip helps a bunch.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by KYBOYI am in the process of setting up a oxy/propane torch ... Anyway what pressure do you like for a oxy/Propane set up? Pretty similar to Oxy/ace???
Reply:I cut with it all day yesterday, scrapped a bunch of old rails. http://s94.photobucket.com/albums/l1...ailRoad007.jpgDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Originally Posted by TozziWeldingI cut with it all day yesterday, scrapped a bunch of old rails. http://s94.photobucket.com/albums/l1...ailRoad007.jpg
Reply:Thank ya'. Im goin' to pick up a T grade hose and some tips tomorrow..
Reply:Propane will cost more in the long run, because of the oxy to fule ratio, but it will allow you to cut thicker and on rusty metal because of the secondary BTU's available with propane over C2H2 (Acetylene)
GMT+8, 2025-12-20 09:03 , Processed in 0.092886 second(s), 18 queries .
