Wire feeder?
发表于 2021-9-1 00:55:43 | 显示全部楼层 |阅读模式
I have an old Lincoln weldanpower ac225 generator welder.  I am wondering what I can do to use this as a MIG or is it even possible?  Can I just hook up any wire feeder?  I don't know anything about this, please help.Last edited by ajholt7; 09-22-2007 at 09:08 AM.
Reply:You said ac225.  Is it DC too?DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Yes it is.
Reply:If it's the CC\CV model like this, you're all set.  Just hook on a wire feeder like the LN-15 or LN-25.WeldingWeb forum--now more sophomoric banter than anything else!
Reply:With this type of set up don't you have to maintain a uniform arc length in order to get good results. I've used the miller suitcase welder with a portable power supply before and found the heat to be all over the place...especially if you alter the arc length.
Reply:Originally Posted by 69 chevyIf it's the CC\CV model like this, you're all set.  Just hook on a wire feeder like the LN-15 or LN-25.
Reply:Where can I find a cheap used wire feeder that will work?  Will any wire feeder work?  What do I look for?
Reply:I have the same machine.  It welds wire awesome.  Set the machine and feeder on CV.  You will need feeder with the wire that takes its power from your welding ground.  I hook the wire directly to the ground clamp, not the work.  A hobart hefty or lincoln LN-25 would be best. It will work better than some shop welders.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:A Hefty or LN25 are voltage sencing feeders and only maintain voltage by electrical stick out (ESO).  not very good for a beginner.  Always for wire a CV machine and a standard feeder are the best. Only spray or FCAW are suitable for voltage sencing feeders.
Reply:Originally Posted by weldgaultA Hefty or LN25 are voltage sencing feeders and only maintain voltage by electrical stick out (ESO).  not very good for a beginner.  Always for wire a CV machine and a standard feeder are the best. Only spray or FCAW are suitable for voltage sencing feeders.
Reply:David I agree.  I use VS feeders all day long.  They run CC, Globular, and Spray without a problem.
Reply:you need to read my answer asgain.  That is exactly what I said.  John
Reply:Originally Posted by weldgaultyou need to read my answer asgain. That is exactly what I said. John
GMT+8, 2025-12-20 10:22 , Processed in 0.090411 second(s), 18 queries .
