查看: 13|回复: 0
question rebuilding tractor bucket T1, AR plate ?
发表于 2021-9-1 00:55:40 | 显示全部楼层 |阅读模式
can anyone give me advice on replacing the bottom section of a front end loader bucket,   its used for some heavy duty excavation.      ive heard of  T 1 and A R plate.   i dont really know the characteristics of these steels  or what should be used in the bucket part itself.
Reply:Are we talking garden tractor or loader tractor. For any tractor under say 5 or so tons, use mild, but if you have a heavier machine, use an AR plate like AR400, and follow its procedures for preheat, low-hy consumables and post-heat.Owner of Bushwacker Mobile WeldingPictures
Reply:T1 - high stenght steel.  Tensile - 115,000 PSI minimum.AR - Abrasion resistant steel Tensile - 190,000 PSI and Brinell hardness from180-200, and 360 - 400 depending on your material seletion.What kind of bucket, size and use(material) /size of machine, etc.Here in the Great White NorthMosquitoes can't fly at 40 below
Reply:If it is a small bucket, make it from mild, and weld on AR-400(and hardsurface) strips in strategic wear spots.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
GMT+8, 2025-12-20 08:59 , Processed in 0.114260 second(s), 18 queries .
