Asme B31.1
发表于 2021-9-1 00:55:40 | 显示全部楼层 |阅读模式
Can anyone outline this for me or give specific details? What is the standard positioning? I did some research online but it doesn't get into specifics. Most places will want to sell you the ASME book. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Best bet is to find a boilermaker and ask them...lol. I can only speculate but I think they test to API 1104. Like you, all I could find in a quick search was folks selling the book.Anything worth doing is worth doing RIGHT
Reply:i can ask at class lollong time no see63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:MIRC....BITTORRENT....EMULE....etc.....learn how to use theseELVIS
Reply:Originally Posted by ElvisWMIRC....BITTORRENT....EMULE....etc.....learn how to use theseELVIS
Reply:What do you want to know?I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
Reply:I think he asking for a heads up on the test. Probably wants to burn some metal in prep for taking test.MaterialProcedureTips, pointers Just my guess, he's a smart guy and probably just wants to do his homework before showing up to test.Anything worth doing is worth doing RIGHT
Reply:You can have the book legally from the library perhaps?ELVIS
Reply:Roger that Olddad. I've got a job offer based off my other work. A local company is in dire need of talented weldors to do pipe work. I'm mildly interested as it's good money and good health benefits. Thanks. I will check the library but I talked with the lead weldor and he said we can just test 5p on the bench...that's it.Last edited by MicroZone; 10-01-2007 at 09:02 PM.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Decision time...good luck John !!Anything worth doing is worth doing RIGHT
Reply:Good luck John!City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:100% on the root as in ALL the edge, a tidy cap with a minimum of .5mm build up and a maximum of 3mm and pretty clean through the guts and you're in, positions etc the same as anything else.    Remember it's just another butt...I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
Reply:Thanks fellas !  I'm going to practice a for a few days before hitting it Saturday.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
GMT+8, 2025-12-20 08:55 , Processed in 0.089950 second(s), 18 queries .
