help me find these rods
发表于 2021-9-1 00:55:39 | 显示全部楼层 |阅读模式
Hello,Sears, once distributed and sold, some very excellent welding rods. I  am hoping you can tell me :Who, made these welding rods that I am about to mention, and.... what equivalent rod and manufacturer  could I get the very same rod  or a very similar welding rod from today?The welding rods I speak of are:Craftsman, contact type, mild steel, Cat No# 9-20296  1/8   E-6024Craftsman, Machinable cast Iron rod,  Cat. No# 9-2027   3/32 E# ???-unknown. But Characteristics of the rod are: recommended for high tensile machinable welds on gray and alloy Cast Iron, without preheating.  Operates with AC or DC Tensile strength of over 60,000 pounds. Hardness is only 140-180 BrinellAmp rating 45-85Craftsman, Non- Machinable Cast Iron Rod, Cat. No#99-20555    Size is 1/8 and 3/32E# is unknown.Characteristics of the rod are: Used for inexpensive, high strength welds on cast iron where machine ability is not required. Used to weld all types of cast iron , or cast iron to steel without cracking or other difficultly. Can be used on clean or dirty iron The coating makes possible the welding of cast iron  (cold) ...room temperature....thus eliminating preheating. Recommended for building up and repairing new castings. Use with either AC or DC current. Amp recommended :3/32 = 45-85 1/8 = 75-130Craftsman, Hard Surfacing Rod, Cat. No# 99-20041 E# unknown... but recommended for applying hard surface that is wear resistant surface to steel or iron parts exposed to wear, abrasion, or Impact.  Use with AC or DC Current.Size  3/32 and 1/8Craftsman, cutting rod, Cat. No# 9-20282   E# unknown.  size: 1/8   For cutting all metals including copper, stainless, and manganese steel and alloys.   for piercing, gouging, cutting, and scarfing. Needs no oxygen, or special equipment to cut.  Has special heavy coating that forms a cone to direct the the intense heat and arc.1/8 with AC , use 150-190 Ampswith DC,  use 170-500 Amps.I greatly appreciate your assistance! Thank you,
Reply:Hey Flywelder, try looking into Arctec alloys products, they have similar ones.Nothing Ever Got Done By Quitting, Never Give Up.
Reply:Hi, Fly.  Sears changes mfg's every year.  who bids lowest.  Lincoln, Hobart, Esab, McKay and many others.  They all have what you want.  good luck
Reply:those rods were made by Hobart Bros.
GMT+8, 2025-12-20 08:55 , Processed in 0.085988 second(s), 18 queries .
