salvaging dome 7018 rod
发表于 2021-9-1 00:55:38 | 显示全部楼层 |阅读模式
I came across about 50 pounds of 7018 rod for the great price of FREE!  The only problem is that these rods were not kept properly. They were kept in open plastic bags or tubes withoutthe cap. The visual check showed that the flux isn't discolored cracking. I ran a random sample earlier today and they seem to be running fine.  They did throw more than usual spatter. (probably me)I was wondering is it possible to drive out the moisture these rods sucked up? I am thinkng of popping about half in the oven at 450 for a few hours and then holding it at 250 for a couple more. Opinions?
Reply:Typically codes call for low hydrogen electrodes to be reconditioned no more than 3 time and out of an electrode oven for no more than two hours. I would say if your doing non critical welds. Welds that don't have to pass a deconstructive test or an xray you should be in pretty good shape.
Reply:No reason not to use them. Free is good! They could stand a high temp bake, then hold at 250*. (The short answer.)City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:http://www.weldingweb.com/vbb/showthread.php?t=14781
Reply:Thanks guys. The Mrs will be away this weekend helping her mother. So I will "bake" some rod and try it against the raw stuff just to see if there is a difference in the way they run. Go1lum, you are right I am not doing anything really critical.
Reply:If the flux stays on, they will weld better and stick less.  Bake at least 2 hours @ 300*f.David Real world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-20 08:55 , Processed in 0.069103 second(s), 18 queries .
