Solar mig ??
发表于 2021-9-1 00:55:35 | 显示全部楼层 |阅读模式
I bought a solar 2114 tote mig 11 yesterday because i wanted the  argon tank for my Maxstar 150 stl which arrived today  Well as it turns out after the 30 mile sunday drive pick up the mig the tank was 75/25 mix not good for tig  so i decided to try the 120 volt mig out as ive never miged with gas.I have the lincoln 140 they bought for me at work but have only used flux wire with it.To my suprise its a makes a nice bead and none of that nasty smoking and splattering like the Lincoln,Which brings me to my question Is the wire supposed to be hot all the time? my Lincoln i can have the wire on the work and nothing will happen till i pull the trigger,this Solar has a Tweco mini mig gun the trigger will start the wire and gas but the wire is already hot you have to like point and shoot is this normal? Thanks guysVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Ye$ some are hot all the time.  Its cheaper.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Cool ,i guess ill keep it around then .Thanks davidVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:There is gas shielded and self shielded Flux Cored Wires, Some DCEP and some DCEN.  The AWS # will tell you all you need to know.SMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
GMT+8, 2025-12-20 09:03 , Processed in 0.093984 second(s), 18 queries .
