Linde in need of foot control
发表于 2021-9-1 00:55:34 | 显示全部楼层 |阅读模式
I have a Linde hda-300 nice shape in need of a foot control, the manual states it requires a fc-3 this is a rheostat style of control, these are hard to find so I am thinking about grafting on a different brand of control, do any of you know if a miller rfc-23a would work if not any other suggestions. The rheostat in the machine is a mallory type300k, 600volt, 300watt, 6ohm that controls from the panel. The plug arrangement can be 4 wires and 1 ground.Thanks for the help.
Reply:Hey! I just saw this http://buffalo.craigslist.org/tls/444527732.htmlnot sure if it's what you need
Reply:These folks can fix you up www.ssccontrols.com. Victor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Thanks for the scc controls lead, this is were I started as well, all of these controls are low wattage around 2 watts, and thanks for the FC-4 lead I have purchases a FC-4 and both are of the low watt type. The control I need is a FC-3 or a rheostat type I think a miller rfc-23a will work, trying to confirm this. Thanks for all the help.
GMT+8, 2025-12-20 08:54 , Processed in 0.088436 second(s), 18 queries .
