Horrible stick beads out of position !
发表于 2021-9-1 00:55:30 | 显示全部楼层 |阅读模式
ok guys im a welding newbie.   I get good beads on the flat but out of position I get horrible beads. BUBBLE GUM !!!!  OK so what is the deal?I feel I am possibly running too hot,  but I get concerned about having a weak weld (no penetration) and probably burn hotter than I should !I was welding some 1/8 thick square tube at about 120 Amps DCEP !   I probably want to be at around 90 to keep the weld pool under control ???  But will the welds hold ?  I probably want a tighter arc as well.Thanks for any tips and advice.  I should be able to get some photos in a week or so of my welds (when I get a chance to get back at it)!
Reply:Originally Posted by Newfie_1986ok guys im a welding newbie.   I get good beads on the flat but out of position I get horrible beads. BUBBLE GUM !!!!  OK so what is the deal?
GMT+8, 2025-12-20 09:03 , Processed in 0.101940 second(s), 18 queries .
