stainless grades of sorts
发表于 2021-9-1 00:55:28 | 显示全部楼层 |阅读模式
I was trying to find all the finish grades of stainless there were from the internet with no luck.  Could someone point me in the right direction?  Also, I would like to find information on what finish grades are needed for different food industries. There seems to be a bit of debate going on in my shop over this.-MikeCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Lots of good information on all grades of Stainless Steel: http://www.nickelinstitute.org/index...i_id/11021.htmJohn -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:This may help as well:http://www.azom.com/details.asp?ArticleID=470
Reply:I did read the azom article.  The nickelinstitute was a good read as well.  I did another search and found this:http://www.askzn.co.za/tech/tech_finishes.htmIt would have been nice to have pictures with each finish type.  But I'm pretty sure I know what they look like.Common sense in an uncommon degree is what the world calls wisdom.
GMT+8, 2025-12-20 10:24 , Processed in 0.079963 second(s), 18 queries .
