3 phase welders
发表于 2021-9-1 00:55:27 | 显示全部楼层 |阅读模式
I know one can run 3 phase machine tools in a single phase shop using static and rotary phase converters or a VFD, but can 3 phase welding equipment be run in a single phase shop using any of those methods?Thanks.
Reply:I looked into this a bit, if im not mistaken the rotary was the best for the application, the thing is that you will need a big 3P motor. Because of inefficiencies you need a motor that draws 30% more current. So if you needed a 100A 3P load you would need a motor that draws 130FLA.My numbers may be a bit off, but thats the basic idea.
Reply:So the VFD will not work with the welders?
Reply:Originally Posted by tanky321I looked into this a bit, if im not mistaken the rotary was the best for the application, the thing is that you will need a big 3P motor. Because of inefficiencies you need a motor that draws 30% more current. So if you needed a 100A 3P load you would need a motor that draws 130FLA.My numbers may be a bit off, but thats the basic idea.
Reply:Originally Posted by mla2ofusIf you run w/ 460v,that will need a 100 HP motor,which will not be cheap and 230V would require a 50 HP motor.                                          Mike
Reply:no, you can't use a VFD for anything other than a motor...
GMT+8, 2025-12-20 08:56 , Processed in 0.067100 second(s), 18 queries .
