im interested in finding out what is the procedure(s) involved in a rebar cert. ive got the structural plate and pipe so i already have a basic understanding i was told there were about four different types of joint tests. a individual cert for that particular joint style. my question is, is there a cert test that qualifies you for more than one type or all joints, or which one would be the most common one to get that qualifies you for the most situations. also what are the steps taken in the test and temperature to maintain and any other hints or advice thanks
Reply:my sudjestion would be to get a hold of a aws book and look up the certs they might be the same were 3/8 rebar cert might cover the larger rebar? john pummer or will daniel at fullorton college in southern cal would be able to answer your question they are welding instuctors and do the certifications .
Reply:Do you have a copy of the AWS D1.4?City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny |
