查看: 13|回复: 0
swaging tube
发表于 2021-9-1 00:55:17 | 显示全部楼层 |阅读模式
A customer is using 2" tri-cover and dairy-type fittings that are welded to a short piece of tube acting as a king nipple.  They need this nipple replace, but one problem:  They have been swaged(or flaired out in the middle) so the hose and clamps wont slide off.  And for the life of me, I cannot find any pieces of tube on the net that I can use.  I have more TC's and dairy fittings. All I need is the swaged tube.  Anyone know where I can get these?-MikeCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Did you try Mcmaster Carr?There website is mcmaster.com, I'll bet they have what you need...Washman
Reply:You could also try swaging the end of 2 short tubes and weld them together.
Reply:McMaster hasnt helped.  I thought about welding two swaged ends together, but the fittings need to be food grade, and that will majorly add to the time with the extra welds.  Maybe I can talk the customer into king nipples.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Hope this helps; http://www.thomasnet.com/products/tu...8623228-1.htmlAnything worth doing is worth doing RIGHT
Reply:Okay.... After a lot of research online and with local suppliers, I have come to this conclusion: They don't make that old-school fitting anymore. I did find a company (JV Northwest) that can stretch the tube to my specs for a pretty penny. I also found out that swage is actually a manufacturer of fittings and such called SwageLok (swagelok.com). I looked though their site and couldn't find anything that was of help. So it looks like I have to go though JVNW for my parts. Here is a pic of one that is slightly modified with my measurements for the order: Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Oh yeah, these photos (aside from the lines and numbers) were done with my Motorola Maxx VE cell phone.  Bye bye camera in the field. Common sense in an uncommon degree is what the world calls wisdom.
GMT+8, 2025-12-20 09:01 , Processed in 0.094430 second(s), 18 queries .
