Fillet Size
发表于 2021-9-1 00:55:14 | 显示全部楼层 |阅读模式
If a 11 mm fillet is called for with a dihedral angle of 90 degrees, what would the fillet size be on the obtuse side of a 110 degree angle?Thanks,Mike
Reply:Originally Posted by QCMikeIf a 11 mm fillet is called for with a dihedral angle of 90 degrees, what would the fillet size be on the obtuse side of a 110 degree angle?Thanks,Mike
Reply:For other angles ( and the way I got this one){1/cos[90-(angle/2)]}x fillet size/2Last edited by Brett; 11-03-2007 at 05:56 PM.A good guess is better than a bad measurement
Reply:Material thickness plays a large role. Depth of fusion (penetration) plays another. Joint prep yet another.
GMT+8, 2025-12-20 08:56 , Processed in 0.069648 second(s), 18 queries .
