Which is the Better Stick welder
发表于 2021-9-1 00:55:06 | 显示全部楼层 |阅读模式
Which is the better stick welder, The hobart stickmate or the Lincoln tombstone AC stickwelder? ThanksThank YouWhiteymin
Reply:This will end up a Ford/Chevy debate... so pick one.  Were it me, I'd look for the machine that was AC/DC.
Reply:I don't know - I've never used either.  But why not add a Miller Thunderbolt into the mix.  I can vouch for it as a welder, and I think they make a cheap AC only welder if that's what you're looking for.  I also agree that an AC/DC welder would be more versatile, but there's nothing wrong with an AC buzz box for simple jobs.
Reply:AC/DC is the choise of champions.   John  "A Little Extra"SMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Originally Posted by slamdvwThis will end up a Ford/Chevy debate... so pick one.  Were it me, I'd look for the machine that was AC/DC.
Reply:+1.  I've had the Lincoln and the Stickmate, the only difference I noted was the DC capabilities on my new Stickmate.  In AC mode, I couldn't tell a difference between the machines when the helmet was down.Hobart Stickmate LX AC/DC, Millermatic 252 & 30A spoolgun, Thermal Arc 185 TIG, Miller BWESmith Oxy-AcBridgeport 2J , South Bend 42" 9AHusky 7.5 HP 22.3 CFM 80 gal compressor
Reply:I would say Hobart  just because of the infinitely variable amperage. I don't like the taps on the Linc. I find them way too limiting. When you are welding thin sheet, a change of a couple of amps can make a huge difference. The Linc will get it done, but the Hobart will do it easier simply due to the adjustment.I also say get the AC/DC.
Reply:Ditto here....be sure its AC/DC since the difference in money is not that much.  Either one will work just fine however have the inifinate adjustment can be a good thing if you're prone to fiddling with your adjustments.  If your just doing welding repairs on thicker stuff I doubt you would notice the difference.MichaelMillermatic 25115" Rockwell Drill Press10" Logan Lathe5hp - 2-stage 80 Gallon CompressorHome Made Sand / Soda Blaster
Reply:Get DC whenever possible, and while I, too, prefer the continuously adjustable amperage on the Hobart, the truth is that when you can etll the difference with your hood down, you're ready for a better machine.But a lot of the Americas has built built by those types of machines.
GMT+8, 2025-12-20 08:59 , Processed in 0.070002 second(s), 18 queries .
