O/A regulators
发表于 2021-9-1 00:55:05 | 显示全部楼层 |阅读模式
I use Oxy/Propane on my rig and I noticed that even if I have the propane set at a low psi of 3-5lbs, the gage will slowly "bleed up" to a higher pressure, not so dangerous with Prop. but with Acetylene not the greatest.                   I am at a loss, any suggestions/ideas would be great   I believe that the regulator is a CXA or CGA something, I cant recall off the top of my head        _ BlackhawkL-Tec PCM-VPi II Hobart Handler140Millermatic 35Lincoln Power arc 4000Lincoln Ranger 10,000 ( 3 ) Longevity Tigweld 160SX Purox O/A setup100lb anvilXLO/servosource cnc mill
Reply:You have a seat that needs to be replaced.  That is a CGA 510.  JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Weldgault, CGA 510 sounds familiar, ill have to check it out see what it looks like in there, and see if they still make replacements                                                 Thanks, Blackhawk.L-Tec PCM-VPi II Hobart Handler140Millermatic 35Lincoln Power arc 4000Lincoln Ranger 10,000 ( 3 ) Longevity Tigweld 160SX Purox O/A setup100lb anvilXLO/servosource cnc mill
Reply:It is not a good practice to go into the insides of a regulator, unless you understand the outcome.  What is the brand name or pic's and I can tell you if it is stilll available.  JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Union Carbide reg. theres a chrome bezel and a chrome t-style handle on it.I would take pictures but im not at home right nowL-Tec PCM-VPi II Hobart Handler140Millermatic 35Lincoln Power arc 4000Lincoln Ranger 10,000 ( 3 ) Longevity Tigweld 160SX Purox O/A setup100lb anvilXLO/servosource cnc mill
Reply:The only thing that is CGA 510 is the gauge to tank fitting style. The regulator is whatever it is. Smith, Victor, etc..
Reply:They are Oxweld and yes, parts are still available.  Your LWS will be able to send it off or repair it in house.  esabna.com or 800-ESAB123 can help if nothing else.  John(The only thing that is CGA 510 is the gauge to tank fitting style. The regulator is whatever it is. Smith, Victor, etc..)   The only reason 510 was mentioned is because he had it in his post (CGA?)Last edited by weldgault; 11-11-2007 at 09:25 PM.SMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:thanks again, ill stop at my LWS on the way home from work tomorow and see what they can do for me.                                                  _BlackhawkL-Tec PCM-VPi II Hobart Handler140Millermatic 35Lincoln Power arc 4000Lincoln Ranger 10,000 ( 3 ) Longevity Tigweld 160SX Purox O/A setup100lb anvilXLO/servosource cnc mill
Reply:Originally Posted by Blackhawkthanks again, ill stop at my LWS on the way home from work tomorow and see what they can do for me.                                                  _Blackhawk
Reply:finally home and looked at the regulator face to face, its a "purox " brand regulator, not Oxweld as Weldgault stated.L-Tec PCM-VPi II Hobart Handler140Millermatic 35Lincoln Power arc 4000Lincoln Ranger 10,000 ( 3 ) Longevity Tigweld 160SX Purox O/A setup100lb anvilXLO/servosource cnc mill
Reply:Oxweld - Purox are mfg. by the same company.  ESAB (Union Carbide - Linde Divn.)  Same thing.  John G.SMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:LOL...wondered how long it would take you to point out the obvious there John...LOLAnything worth doing is worth doing RIGHT
Reply:olddad, nice to see you again.  I am slow at times, but most times I get around to it, get it  (A Round Toit).    John     SMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Here you go, John.Don't say I never gave you nothin'!City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:I have several hundred of those around my house and car.  Thanks,now  others know what it is.   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:my wife wanted some carpet laid and i told her i would do it as soon as i could get around to it,.....she turns around and pulls one out of a drawer and says heres one.......nuff said...carpet is down and she hid the round tuit, she says it was for "future reference". some days ya just cant win. ha ha. i guess she knows me like a book.
GMT+8, 2025-12-20 09:03 , Processed in 0.089250 second(s), 18 queries .
