Not So Many Scenes From A Welding class..
发表于 2021-9-1 00:55:05 | 显示全部楼层 |阅读模式
Sorry everyone..Yes I know this is the second time now with very little pics to show..(only 3)What do you want from me?I was teaching.. And no Hotrodder we did'nt do the BFH thing with 5356 VS 4043 yet..Next week.. All in all it was GREAT!Everyone is better at what they want to weld now..Did a little of everything TIG wise and everyone had ample "seat time" to try it all..Stainless..Mild steel..Aluminum..Gas mix vs straight argon..Positioner..Even fixed a crack in a "Cross Ram" 426 Intake ('65 Chrysler stuff) thats EXTREMLY expensive..Still have more to do on the other one so I will post pics..We did however do the BFH deal to some 1/4" Stainless that was fusion welded only and broke the vice trying to get it to break..Tozzi broke out the O/A torches and did some cutting..Then some arc gouging..Thanks Tozzi!Always a pleasure..Then we cleaned up and headed to the bar..I'm sure others took pics and you can post them here..I'd like to see them too.. Had representives from Tennessee, New York, Connecticuit, Toronto Canada,California and here in Mass.Quite a turnout..I was impressed!I hope everyone makes it home safely..We'll do it again sometime in early March...Thanks again guys!And be sure to turn the tungestion grinder off when done.....zap!Last edited by zapster; 11-10-2007 at 04:57 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:No pictures only memories. Thanks for the class zap.
Reply:Anytime!Your more than welcome next time if you wish......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:AHHHHahahahah!!!!"Don't forget to turn the tungsten grinding wheel off when done"     ""I HEARD THAT""Lew Ray weld it like you own it
Reply:Originally Posted by lewrayAHHHHahahahah!!!!"Don't forget to turn the tungsten grinding wheel off when done"     ""I HEARD THAT""Lew Ray
Reply:THANKS ZAP! It was a pleasure metting all you folks and getting to try some TIG welding I've never done before.
Reply:Zap,Thanks for the time. It was well worth the trip. My total was about 500 miles round trip and about 4:15 for the run home.The time running Ar 100% V.S. Ar/He ~ 38/62% was key for me. Now I have to get another bottle and a mixing solution I will have to see about bringing my Dynasty next time.ThanksJim
Reply:OK so I mentioned a web based tig pulse calculator, it is on Pro-Fusion's site.http://www.pro-fusiononline.com/welding/pulsing.htmWelding With Arc PulsationArc pulsing involves using the welding power supply to rapidly alternate the weld current from a high (peak current) to a low (background current) value. This welding technique brings many benefits to the welding procedure, often improving weld quality and repeatability. In some cases materials and weld joints that are difficult to successfully weld with a non-pulsed arc can easily be welded with a pulsed arc technique.Arc pulsing involves four welding parameters: peak current, background current, pulse width (duty cycle), and pulse frequency. It is important to understand how to choose convenient weld development starting parameters and the effect on the weld by changing each parameter.Benefits Of Arc Pulsing   1.  Lower Heat Input To Part          * Defeating thermal conductivity   2. Improved Weld Depth/Width Ratio          * Narrowing of the arc          * Defeating thermal conductivity   3. Arc Puddle Control          * Control of arc puddle convection flow          * Due to arc force and magnetic effect          * Degassing benefit, minimizes porosity          * Puddle freezes faster, this helps defeat gravity in out of position welding   4. Arc Stability          * Less arc wander or problems with weld pool surface tension   5. Increased Weld Speed          * Smaller/shorter weld pool allows for faster travel          * Puddle agitation/mixing          * Improved arc stability   6. Improved Weld Quality          * Reduced heat affected zone, improved weld depth/width ratio          * Improved weld appearance and consistency          * Control of arc puddle convection flow          * Even distribution of slag/contaminant          * Reduced porosity, reduction of oxides          * Faster solidification rates provide a finer dendritic structure          * Reduces dilution of dissimilar materialshttp://www.pro-fusiononline.com/welding/pulseparams.aspAnd another on Pulse Frequency Ratehttp://www.pro-fusiononline.com/welding/pulserate.aspJim
Reply:We did however do the BFH deal to some 1/4" Stainless that was fusion welded only and broke the vice trying to get it to break..
Reply:I made it back to Buffalo at ~1:15 AM Sunday.  I stopped for ~45 minutes in the cartskills to pick up a late and lade a wrong turn along the way which added about a hour to the trip.  Zap, I learned a bunch.   Thanks for putting this on.  As soon as the good weather rolls around again, I'd like to come back.All: I picked up some great info from watching everyone else also.  It was nice to meet you all.Here are some pics from the class:Ryan Attached Images
Reply:more picsRyan Attached Images
Reply:Last pic.  Kinda blurry, but this is the SS fusion welding.Ryan Attached Images
Reply:Looking good! Looks like people from all over made it.
Reply:It is always a great time Zap, and to who ever left the welding hats in my truck thanks.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Zap, welding away, on a project for one of his co-workers. http://i94.photobucket.com/albums/l1...trodeID003.jpghttp://i94.photobucket.com/albums/l1...trodeID004.jpgDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Damn..Thats my bad side.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-20 08:59 , Processed in 0.078338 second(s), 18 queries .
