JW Harris 20 Gauge Cored wire
发表于 2021-9-1 00:55:04 | 显示全部楼层 |阅读模式
Anyone ever use this stuff?http://cgi.ebay.com/New-JW-Harris-20...QQcmdZViewItem I have some sheetmetal to work on and was curious how it worked and settings for 18-24ga.  I have used .023 wire before, looking at possible alternatives that may be easier to use.. Thanks
Reply:It makes no since, What AWS # do you want.  The 20 Gauge wire of JW Harris (20 ga) is .036, our normal size is .o35 and a certwin type of wire (E71T-1, E70-TG, or something.   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Cracked,I am on my third 2# spool and I like it.  I think it is a "little" better to handle than standard wire BUT I am only a hobbyist practiced on automotive sheetmetal.  My advice is to buy a spool and run it yourself, on your equipment, in your type of welding.As to it not burning thru on sheetmetal that is a little hype - any wire can burn through under the right conditions.   For me Twenty-Gauge is more forgiving.BTW: "Twenty-Gauge" is not 0.036" diameter, it is a standard 0.030" diameter wire that uses normal feed parts.Paul
Reply:Read the site.  20 Ga. is .036    JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:T H E H A R R I S P R O D U C T S G R O U PA L I N C O L N E L E C T R I C C O M P A N Y4501 Qual i ty Place • Mason, OH 45040 U.S.A Tel: 513-754-2000 Fax: 513-754-6015TECHNICAL SPECIFICATION SHEETAll statements, information and data given are believed to be accurate and reliable but are presented without guarantee, warranty or responsibility of anykind, expressed or implied.Additional information available at our web site: www.harrisproductsgroup.comPerfect Circle® Welding Wire Twenty Gauge™(brand).030 DIA. CORED WELDING WIRELast edited by Steven DeMars; 11-16-2007 at 03:42 PM.Millermatic® 251
Reply:I was given a roll by my LWS to try. In my mind its all hype and overpriced but for a beginner it may be fine. I can't see spending 6 times what i can buy solid wire for and you still need the gas. I went to the boneyard and got a truck door to try it on. It welded fine, but any better than my .023 S6, not really. It would still burn thru if you wanted it to. So i guess its what you want and need to use but i wouldn't spend the extra on it. Just my .02...BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
GMT+8, 2025-12-20 08:55 , Processed in 0.070132 second(s), 18 queries .
