Chrome ??
发表于 2021-9-1 00:55:03 | 显示全部楼层 |阅读模式
At work were constantly tossing old tables,desk and chairs,You know  the heavy duty Formica,particleboard and bubble gum kind, [community college] Well the tops are junk but the legs are nice steel in different shapes [round, square, rectangle] mostly chrome finished.My question is is that stuff safe to weld on? I think Ive heard bad things about chromium  Id start salvaging some for projects if its safeVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:You need to grind the finish off before you begin welding.
Reply:Here's a little info on chrome. http://www.thefabricator.com/Safety/...le.cfm?ID=1336Search for 'hexavalent' chrome and you find way more than you want. Clear up to the "abandon the planet" level. Just use common sense.
Reply:Originally Posted by SandyHere's a little info on chrome. http://www.thefabricator.com/Safety/...le.cfm?ID=1336Search for 'hexavalent' chrome and you find way more than you want. Clear up to the "abandon the planet" level. Just use common sense.
Reply:http://www.osha.gov/OshDoc/data_Gene...t_chromium.pdfPersonally I don't sweat it much other than it's a pain. Lot of stuff that's plated is thinner than I have a use for. Freebee stuff is all short pieces.  A lot of the good plating is setting on a layer of copper too. Hard on band saw teeth. Sharp as a razor if it peels or flakes. Spits pops and raises heck when you don't get it off.If you are health conscious then you should read up.
GMT+8, 2025-12-20 09:03 , Processed in 0.093386 second(s), 18 queries .
