welding rods in oven
发表于 2021-9-1 00:54:59 | 显示全部楼层 |阅读模式
I use 7018ac,6011 6013 rods   i am pretty sure i have moisture getting into these rods just from storage. maybe not alot but some, my question is do i need to put these in an oven for a while to be sure theres no moisture.i have a small bakers oven i can use for drying with temp from 0 to 450 degrees.how long to dry & at what temp.  thanks for your advice.
Reply:Of the rod types you mentioned, 7018 are the only low hydrogen rods that must be kept dry.  Check Lincoln's website:http://www.lincolnelectric.com/knowl...nt/storing.aspfor instructions on re-baking rods to drive off moisture.  Commonly held belief is that re-baked rods are never quite as good as those that are fresh.  YMMV.Last edited by A_DAB_will_do; 11-24-2007 at 08:05 AM.
GMT+8, 2025-12-20 09:38 , Processed in 0.069804 second(s), 18 queries .
