? preserving welding lead neoprene
发表于 2021-9-1 00:54:52 | 显示全部楼层 |阅读模式
Anyone know of anything you can put on welding leads to preseve the inulation?        Keep it from cracking?
Reply:Store them out of the sun and keep any grease or oil wiped off of them.
Reply:The welding leads should not rot easily they have already went through a treating process called vulcinazation. This helps the mechanical and chemical properties of the material. --Gol'
Reply:Originally Posted by 123weldAnyone know of anything you can put on welding leads to preseve the inulation?        Keep it from cracking?
GMT+8, 2025-12-20 09:38 , Processed in 0.095238 second(s), 18 queries .
