Positioner-?
发表于 2021-9-1 00:54:51 | 显示全部楼层 |阅读模式
Where would I look to buy a positioner? Never even looked before. Do they also have another name or just positioner?  Just looking for something inexpensive.Thanks,Dave
Reply:Try Mitroski's in Houston, Texas.  This is all he has and reconditions what he buys.  JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Van Sant Enterprises. WWW.Trick-tools.com . 1-877-Van Sant is the phone #. They are from $1700 to $2600. OUCH!!!!And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:E-Bay.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:i think this is what weldgault was refering to...http://www.mitrowskiwelding.com/Later,Andy
Reply:McMaster Carr also sells them new
Reply:If your thinking about a larger positioner; production forklift attachments can be a good start. Some of them, such as rotators,  paddle clamps, and tips,  are practically ready made weld positioners. http://www.cascorp.com/americas/en/p...s!OpenDocumentAt trade in time, most odd-ball specialized attachments are pulled, and replaced with conventional forks.  They are plentiful, and cheap, on the used market.
Reply:Originally Posted by denrepIf your thinking about a larger positioner; production forklift attachments can be a good start. Some of them, such as rotators,  paddle clamps, and tips,  are practically ready made weld positioners. http://www.cascorp.com/americas/en/p...s!OpenDocumentAt trade in time, most odd-ball specialized attachments are pulled, and replaced with conventional forks.  They are plentiful, and cheap, on the used market.
Reply:More exspensive than thought weld it like you own it
GMT+8, 2025-12-20 11:17 , Processed in 0.261340 second(s), 18 queries .
