Bobcat or Ranger 3 phase
发表于 2021-9-1 00:54:50 | 显示全部楼层 |阅读模式
Many of you know that both the rangers and bobcats are available with 480 3 phase aux power. Has any any of you use the option? If so what is the largest motor that you've ran off of them? I have to buy a welder for a new facility or buy a new one for me and send them my used welder. Well, that's a no brainer. If these machines could start and run a 10 hp compactor or baler we would buy one, otherwise I'll be buying Ranger GXT, Ranger 250 or Bobcat 250. These compactors only pull a full load for a few seconds during a 1-1 1/2 minute cycle.
Reply:According to the engine driven welder section of the Radnor Products catalog (Airgas) a high torque 10HP motor runs on 10700 watts but has a startup requirement of 46700 watts.Even the 7 1/2 HP high torque requires 35000 at startup according to the same chart.Anything worth doing is worth doing RIGHT
Reply:Hello from Missouri. I am from Marshfield just east of Springfield. I have done a little deer and hog hunting in your area. On the the point. I have a Bobcat 3 that I use everyday I run my Miller Matic 350P with no trouble and a friend has a 11hp compresor that we ran one day for sand blasting and we had no trouble. I do not have a single complaint on this machine. I run up to 3/16" rod with a little power to spare. I get decent econimy from it. If im using the 3phase to MIG weld I use about half the gas as stick welding. Thursday I loged 6 hours welding on aluminum non stop and burned about 1/4 of a tank if im stick welding 3/16 rods like on Wendsday I had 4 hour solid and used just over half a tank. Keep in mind my 350p is inverter based but will pull 11,000 watts wide open. I think the Bobcat will do just fine for your need and a better price in my book. Airgas out of Springfield did me ok when I was there but if you dont mind ordering consider uswedling.com. Call and ask for Joe they will take care of you. Steel Thunder Welding LLC. St. Thomas VI USAMM350PBOBCAT 3MAXSTAR 150 STH375 EXTREME PLASMA6.5 HP COMPRESORDEWALT 18, 24, AND 36 VOLTO/A TORCH SETAND SO MUCH MORE I DONT REMEMBERALL IN MY 2005 2500HD EXTENDED CAB L/B
GMT+8, 2025-12-20 09:38 , Processed in 0.189504 second(s), 18 queries .
