Two Miller Bobcats In Tandem
发表于 2021-9-1 00:54:45 | 显示全部楼层 |阅读模式
I want to use 2 Miller Bobcats to arc gouge. Both set on 150 amps. Both connected to arc gouging rig. Have 150 cfm compressor. Good, bad, or just downright stupid thoughts. Thanks, Billy
Reply:You do know that arc gougging is dead shorting those machines.  What size carbons are you going to use and remember that volume and presssure are different.   John                        Welcome   SMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:From what I have read in all the Lincoln literature, its no problem as long as both machines are the same and set the same.  I have never done it my self.Sounds like fun gouging with 300 amps.  You gonna use 1/4" carbon?DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I have hooked 2 500 amp machines together for quite a bit of work before. As long as they are set about the same things will be fine.
Reply:Thanks for all of the replies. Will try it today. Again many thanks, Billy
Reply:Parallel right?  + to + and - to -.Just making sure.DavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-20 11:17 , Processed in 0.101747 second(s), 18 queries .
