What Welding Certification needed for Structural Ironworking
发表于 2021-9-1 00:54:44 | 显示全部楼层 |阅读模式
I was accepted into an apprenticeship program at my Local Union hall for Structural Iron working but classes aren't starting for a while.  I want to find a job for a company in the mean time but I have no experience.  I thought it would help to take a class to learn how to weld to offer the company something.  Can someone please tell me where I could go to learn how to weld and what kind of welding I would need to get a certificate in?  Thanks for your help.  I live in SE Michigan by the way.  Thanks again. Marc
Reply:Welcome Marc and there are 100"s of certifications you can get.  What kind of welding do you want to do, look at my sig.   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Thats the thing, I don't kow what kind of welding you need to know for Structural Ironworking.
Reply:SMAW (Stick) GMAW,MIG (wire), GTAW, TIG (heliarc), all of these.  JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Originally Posted by MJKThats the thing, I don't kow what kind of welding you need to know for Structural Ironworking.
Reply:Goals that come to mind, learn to cut with a torch and learn to stick weld with E7018 and learn to run Flux Cored wire and learn to Air Carbon Arc gouge.When it comes time to test for your certificate, you will probably want to test in the vertical and overhead positions, that being said, practice vertical the more.Last edited by tanglediver; 12-07-2007 at 02:15 PM.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:for structural steel welding the main processes are:shop = fcaw-g 80%, gmaw(er70s or c -3 or 6 10%, smaw (7018) 10%field = fcaw-ss 90%, smaw (6010 and 7018) 10%
Reply:You will most likely be using 6010 and 7018 the most. If you are starting an apprenticeship program, don't go and get a non union job for a competing company. The union will throw you fast if they find out.Bill
GMT+8, 2025-12-20 09:40 , Processed in 0.157701 second(s), 18 queries .
