Spool Question
发表于 2021-9-1 00:54:36 | 显示全部楼层 |阅读模式
Ok, well, I've tried to get info and seem at a deadend.  I have the MM135 machine, and the actual wire spool mounting hole is pretty big in it, but it seems all the local places sell spools with SMALLER holes in them, the bigger ones being mostly for 10lb spools and such.  What is the deal, can i fit a smaller diameter hole on there somehow, so i don't have to spend 60.00 on a 10lb spool?Have a Jeep Cherokee?  Click Here!
Reply:Originally Posted by SkwerlyOk, well, I've tried to get info and seem at a deadend.  I have the MM135 machine, and the actual wire spool mounting hole is pretty big in it, but it seems all the local places sell spools with SMALLER holes in them, the bigger ones being mostly for 10lb spools and such.  What is the deal, can i fit a smaller diameter hole on there somehow, so i don't have to spend 60.00 on a 10lb spool?
Reply:This post was a duplicate disregard. Thanks       Sincerely,             William McCormick
Reply:So it's something extra i have to order then eh?  Swell haha.  Thanks for your reply!  Anyone else have this issue ever, or am i being a big baby?Have a Jeep Cherokee?  Click Here!
Reply:I don't know if they're the same setup or not but my MM180 has a removable larger diameter sleeve which came with the unit.  The online owners manual for the MM135 reads just like my 180. It adapts between the 4" and 10" spools.  The adapter was included with mine.TimMiller Dynasty 200DX; MM180; Spectrum 625; Bobcat 3-Phase; and counting...
Reply:We have the Millermatic 175 here and it fits the 8" dia. spools they sell at Lowe's and Home Depot fine with no modifications, same story with my new Millermatic Passport and my neighbors Millermatic 180.  I've not tried yet to fit a small spool-gun size spool onto the any of them.   On my HTP there is a spacer sleeve for 8" versus 12" to take up the difference in width so the skinnier 8" spool stays centered behind the drive rolls.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:if you use much wire at all you will want to compare prices on the small rolls and the big rolls, around here pound for pound the 10 pound rolls are a bunch cheaper. plus you aint changing rolls a lot. the small rolls dont last very long.
Reply:Read the manual to see if it shows how to use a 4 inch spool in your machine. I have a millermatic 251 and the manual that came with it shows how to use a 4 inch spool by removing the large spindle and adding a small spring to the shaft that the large spool rides on. Yours might work the same way.
Reply:About the $60 a roll. The local True-valu sell a roll of ER-70-s for $29.95 that is a steel. The 33# rolls cost $155 here and $90 in the states. For the 1# rolls (spool gun wire) they get $4 to #5 a roll. I but 10# wire here if I run out between orders. Steel Thunder Welding LLC. St. Thomas VI USAMM350PBOBCAT 3MAXSTAR 150 STH375 EXTREME PLASMA6.5 HP COMPRESORDEWALT 18, 24, AND 36 VOLTO/A TORCH SETAND SO MUCH MORE I DONT REMEMBERALL IN MY 2005 2500HD EXTENDED CAB L/B
GMT+8, 2025-12-20 10:03 , Processed in 0.465973 second(s), 19 queries .
