axel housing
发表于 2021-9-1 00:54:36 | 显示全部楼层 |阅读模式
I have a job coming in the morning that I am not sure about as I have not done it before. I have to weld the axel tubes into the rear housing for a guy.What rod should I use for this or O/A or TIG, MIG?Of course MIG would be my first choice if 70s wire is okSA200,Ranger8,Trailblazer251NT,MM250,Dayton225AC,T  D-XL75,SpoolMate3545SGA100C,HF-15-1  RFCS-14 When I stick it, it stays stuck!
Reply:Originally Posted by mooseyeI have a job coming in the morning that I am not sure about as I have not done it before. I have to weld the axel tubes into the rear housing for a guy.What rod should I use for this or O/A or TIG, MIG?Of course MIG would be my first choice if 70s wire is ok
Reply:Originally Posted by RojodiabloCurrie mig welds their axles, you will be just fine.
Reply:Yep MIG TIG STICK  its all good GMAW is most practical  weld it like you own it
Reply:Ok, it was an 8.8 ford with the plug welded holes. The guy wanted a bead around the outside. Wound up with stick 7018 due to the rust in the crack between the housing and the tubes. He was happy and I was tickled. We used the barter system and he is going to replace the condenser on my wifes ride in exchange. All I have to do is buy the part. Includes vacuum and recharge. I made out like a big dog, woo hoo.SA200,Ranger8,Trailblazer251NT,MM250,Dayton225AC,T  D-XL75,SpoolMate3545SGA100C,HF-15-1  RFCS-14 When I stick it, it stays stuck!
Reply:who fixes a ford 8.8...but anyway... didnt we just have a big discussion about welding steel to cast iron in another thread and it was deemed it couldnt be done with any strength?I like to party!
Reply:8.8 are quite strong. I saw a mustang 2 with 750hp and an 8.8. I do not know why he did it but he told me new gears and bearings and 2 seasons no trouble. WHO NEW Steel Thunder Welding LLC. St. Thomas VI USAMM350PBOBCAT 3MAXSTAR 150 STH375 EXTREME PLASMA6.5 HP COMPRESORDEWALT 18, 24, AND 36 VOLTO/A TORCH SETAND SO MUCH MORE I DONT REMEMBERALL IN MY 2005 2500HD EXTENDED CAB L/B
Reply:Originally Posted by CaptainWillywho fixes a ford 8.8...but anyway... didnt we just have a big discussion about welding steel to cast iron in another thread and it was deemed it couldnt be done with any strength?
Reply:Cast Iron Vs Cast Steel.
Reply:Originally Posted by newstickwelderAn 8.8 is perfect swap for a jeep due to the strength, availability, and similar wms-wms measurements. I could be wrong but i also believe the pumpkin is cast steel and not iron... As far as the WHY in welding the axle tubes together.. its because the stock tubes have been known to spin out of the housing breaking the 2 spots welds on each tube.... so the tubes are welded to prevent this...
Reply:Originally Posted by CaptainWillyI wasnt wondering why the tubes were welded...  just remebered some other thread someone was trying to weld a mild steel bracket to a cast iron housing and it was widely accepted to be impossible for strength. The factory plug welds really just lock the tubes in the housing and dont need to penetrate the housing. and if welding cast iron (the housing) to steel (the tubes) isnt strong. why bother?  <---- trying to learn not be a jerk.refering to this discussion... http://www.weldingweb.com/vbb/showthread.php?t=16543
Reply:The center section of the 8.8 is not cast iron. I used a grinder to try to remove the rust prior to welding and the sparks were bright yellow. It welded very easily with 7018 and did not show any signs of cracking.  This unit was being readied for a mustang drag car, hence the beef up. And I did do him a favor as he could not find another weld shop that had time to do this small job in his time frame since he is the son of my friend and is due back in the marines and was just in from Irac. I would have done it for nothing but I had already talked to my friend about the condenser job and he offered the barter.  Thanks to all our armed forces, we can have all these hobbies and freedom to talk about what the h@^%^ ever we want to, weather all agree or like it or not. Thanks folks!SA200,Ranger8,Trailblazer251NT,MM250,Dayton225AC,T  D-XL75,SpoolMate3545SGA100C,HF-15-1  RFCS-14 When I stick it, it stays stuck!
Reply:8.8 are great .....fine for the cause weld it like you own it
GMT+8, 2025-12-20 10:03 , Processed in 0.232390 second(s), 18 queries .
