Edge hardening info
发表于 2021-9-1 00:54:36 | 显示全部楼层 |阅读模式
The cutter blade on my box blade is worn down to where it needs some attention but the company that made the box blade doesn't sell the replaceable cutter blades and, if I buy one from someone else, not only will it be expensive, i'll need to drill new holes.  A friend suggested I use a hard rod and edge harden the existing cutter blade.  Can someone please explain how this is done, what sort of rod I should use and any special techniques required to do it.
Reply:Hard facing rods work great and are not really hard to use. There are 3 basic typea or rod. Abrasion resistant, Imact reststance, And metal to metal. If you contact your local LWS they will have them. As a cutter you would need the AR rods. Some companys sugest a base rod som dont. If they do get them and the welding will go a lot better. If not use a 7018 as a base rod to build up and bad spots and then cover with the hard rods. Dont over weld to much as they are very hard to grind. The weld will look crapy usualy but dont wory all you are dong is leaving a deposit on the surface. Also check the voltage type be it ac ac/dc or dc becaus thay are diferent and will barly weld at all. One last rambaling thought most hard rods like a very long arc length so experiment around and find the best setup. Goog luck and at least try one Steel Thunder Welding LLC. St. Thomas VI USAMM350PBOBCAT 3MAXSTAR 150 STH375 EXTREME PLASMA6.5 HP COMPRESORDEWALT 18, 24, AND 36 VOLTO/A TORCH SETAND SO MUCH MORE I DONT REMEMBERALL IN MY 2005 2500HD EXTENDED CAB L/B
Reply:thanks for the info.  it's exactly what i needed to know
GMT+8, 2025-12-20 09:57 , Processed in 0.091122 second(s), 18 queries .
