Cost of Argon?
发表于 2021-9-1 00:54:34 | 显示全部楼层 |阅读模式
I have been purchasing Argon at the local Praxair of a while.My bottles have been costing 45.00 for a refill, today when I went to get my usual fix the bottle cost was 70.00. Has there been an increase in the cost of the gas in last couple of months that warrents the increase in cost? Or is my Praxair dealer just taking the oportunity to take liberties with my wallet?s.r.
Reply:They take what they can get away with, all of them.   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:You don't mention the size cylinder you are getting filled so I can't say if the price is good or bad.  However, I filled a 80 cubic foot cylinder last month for $26 in Loganville, GA.
Reply:Praxair just instituted a hug hike in cost last month. My big argon went from 128 to 183 I was told fule cost and energy cost to porduce. You should ask around not all will be the same. Steel Thunder Welding LLC. St. Thomas VI USAMM350PBOBCAT 3MAXSTAR 150 STH375 EXTREME PLASMA6.5 HP COMPRESORDEWALT 18, 24, AND 36 VOLTO/A TORCH SETAND SO MUCH MORE I DONT REMEMBERALL IN MY 2005 2500HD EXTENDED CAB L/B
Reply:Airgas is charging $75 for a 160 cu. ft. cylinder exchange with all the taxes and fees. I'm unhappy and I'm going to start shoppng around for the next cylinder. Praxair and barnes are less expensive.Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
Reply:my bottle is a 160
Reply:Originally Posted by offrdfun73Praxair just instituted a hug hike in cost last month. My big argon went from 128 to 183 I was told fule cost and energy cost to porduce. You should ask around not all will be the same.
Reply:24 dollars for a 125 cu. ft. but some places are charge 14 extra for haz mat fee they saaaayyy it goes to uncle samVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
GMT+8, 2025-12-20 10:03 , Processed in 0.429325 second(s), 18 queries .
