cast aluminum
发表于 2021-9-1 00:54:32 | 显示全部楼层 |阅读模式
there is a cast aluminum bracket on my truck that holds the power steering pump on and it is broken. how hard is it to weld cast aluminum? and will it hold?G3miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:Not hard at all if you take your time, prep it properly and clean it. Again, if the above is adhered to, it will hold forever. Reference this post: http://www.weldingweb.com/vbb/showthread.php?t=12795John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Yes you can.  Clean it thoroughly.  Don't use abrasives with aluminum oxide in them.A trick I learned here is to go over the piece with the torch and no filler.  This will float some of the crap to the top so you can clean it again.  It also preheats the piece.Here is a golf cart clutchhttp://www.weldingweb.com/vbb/showthread.php?t=15798Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by G3farmsthere is a cast aluminum bracket on my truck that holds the power steering pump on and it is broken. how hard is it to weld cast aluminum? and will it hold?G3
Reply:Very good points Dave, thanks for the addition.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:thanks for all of the advice. now i just need a tig welder and experience.thought about taking it to a welding shop to see what they could do with it.G3miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:anybody around the west knoxville area that could help a fella out???make it worth your while!!engloid??G3miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
GMT+8, 2025-12-20 09:57 , Processed in 0.078997 second(s), 18 queries .
