Between Lincoln,Miller, Hobart,etc versus Clarke
发表于 2021-9-1 00:54:31 | 显示全部楼层 |阅读模式
Ok guys Im trying hard to get some information. I bought a Clarke 95 fluxcore welder for light duty easy portability use. I noticed after looking over everything that the weight of the welder is 34lbs. I thought that sounded light, so I looked up some small amp Lincolns, Hobarts, and Millers. And they were listed between 42- 50 lbs. What would make the Clarke that much lighter than the others? I got it for 140.00. Thanks for your help fellas.Whitey
Reply:tttop
Reply:You already posted this at least several times. Your answers are here: http://www.weldingweb.com/vbb/showthread.php?t=17667John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
GMT+8, 2025-12-20 09:58 , Processed in 0.161426 second(s), 18 queries .
