How may psi ???
发表于 2021-9-1 00:54:31 | 显示全部楼层 |阅读模式
Hey,i just went to a different gas supplier to exchange my 125cu argon cylinder .My gage shows 1400 psi  that seems short of what i usually get what should i have? thanks fellasVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Look on the cylinder for Icc 1800, 2015, 2265 or 2400.  Answer that and I can tell you how much pressure should be in the cylinder.    John G.SMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Originally Posted by clark-kentskiHey,i just went to a different gas supplier to exchange my 125cu argon cylinder .My gage shows 1400 psi  that seems short of what i usually get what should i have? thanks fellas
Reply:1,400 does sound low. Here in No. Cal. my argon cylinders will typically read right at 2,000 psi when full from the LWS. You might want to query your dealer and maybe exchange that cylinder if it is not full......Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
Reply:Originally Posted by gnm1091,400 does sound low. Here in No. Cal. my argon cylinders will typically read right at 2,000 psi when full from the LWS. You might want to query your dealer and maybe exchange that cylinder if it is not full......
Reply:No #s begin with icc on it, 60 degrees this morning maybe 76 now.So from what you say no matter what 1400 is low.It seems if i recall its usually over 2k .guess i could complain but work paid for this one, as a project I'm doing requires it or so they were told Victor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Originally Posted by clark-kentskiNo #s begin with icc on it, 60 degrees this morning maybe 76 now.So from what you say no matter what 1400 is low.It seems if i recall its usually over 2k .guess i could complain but work paid for this one, as a project I'm doing requires it or so they were told
Reply:where did you get your cyclinder at, a major lws or a mom and pop lws?i bought some c25 cyclinders from a mom and pop lws, returned the tank for a swap out (left it early in the morning before they opened and picked it up later that afternoon), when i got the tank back it was the very one that i took in, no biggy until i got home and hooked the regulator to it and only had 1500 psi in it, should have been 2500 psi. come to find out they were refilling the tanks themselves from a larger tank and could not completely fill the smaller tanks. they gave me some credit and an explanation that that was not one of their tanks, luckily i had the receipt.G3miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:Hmmmm,I think your on to something there G.I sent a coworker out with my tank and he brought the same one back.They didn't even change the tri-gas label I was happy cause it was a nice looking tank till i read the psi.And yes its a real small place, two brothers and a couple welders for sale.I guess ill go ahead and say something   as it is close to work.One more chanceVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Originally Posted by clark-kentskiHmmmm,I think your on to something there G.I sent a coworker out with my tank and he brought the same one back.They didn't even change the tri-gas label I was happy cause it was a nice looking tank till i read the psi.And yes its a real small place, two brothers and a couple welders for sale.I guess ill go ahead and say something   as it is close to work.One more chance
Reply:The same 24$ but without the 14$ haz mat feeVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Originally Posted by clark-kentskiAnd yes its a real small place, two brothers and a couple welders for sale.
Reply:At those prices, quiet expensive.  JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:You might want to leak check the threads between the valve and tank and the valve stem with some soapy water.  It may have started out at 2000 psig.TeddCoHTP Microcut 400 & Invertig 160DC  Smith Dual Guard MD-510 OA Rig  Lincoln SP135+  Hobart Stickmate LX 235/160
GMT+8, 2025-12-20 10:03 , Processed in 0.108176 second(s), 18 queries .
